Lower servo motor location
Does anyone know which side is the lower exhaust servo motor located?
I want to install a Healtech switchable es eliminator and i was told to install the switchable one on the lower and the es eliminator on the other.🧐
Does a single Healthtech module connect to both servo control cables (left & right exhaust)? Or, do you need to purchase two modules, similar to the Servo Buddy modules..?
The below picture looks like a single Healthtech module covers the whole job...
I’m literally doing the same thing now, following advice from forum members Ive ordered two of these Healtech ESE-BM1 modules. Pic below for you. About £45 each (from Motorworks, an established UK independent BMW parts supplier).
If you remove both servos and cables, that's the way to go. Personally I'll stick with 2 switchable ones, it'll be more like Dr Jekill and Mr. Hyde system.
