Here is mine. They copied my rivet structure. You drilled the frame for hanger installation? Upon further inspection, I see that you used the rear stock exhaust bracket 10mm bolt hole to mount the muffler.Just finished making my custom ẽxhaust...feel great
Yes...i drilled a little holeHere is mine. They copied my rivet structure. You drilled the frame for hanger installation?
only 1 support at the muffler.Just a curiosity question. Are the only support points for the exhaust the cylinder head and the holes you drilled in the frame? Or, did you also use the stock mounting points under the engine.
