For Sale Aux driving lights harness
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1768230793#check"></use></svg></i> Discussion starter Discussion starter fleabag
fleabag
R 18B
If you are planning on installing the TC aux driving lights on your bagger, you will need this part. The new blinkers that you will install require this cable to change the gender of the plug from the blinkers to the existing plug under the front dash. You can either use this part, or you can cut and solder the wires. There are two cables in this package, enough for the left and right blinkers. $65 for both, free shipping in the US. (Dealer cost is $46.28 each)
61111692240 |Adapter lead LED turn ind
