Engine fault warning
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1770955273#check"></use></svg></i> Discussion starter Discussion starter Soldaat01
Soldaat01
Belgium
R18
Hello fellow R18 riders,
Yesterday I got confronted with a dreaded engine warning notification and warning light.
Tomorrow I'll be going to my local service center to have it checked out but I'd love to hear what you guys think it will be. My R18 can be started without issue on the first try, and runs normal. The only thing that I can notice is what I think is my fuel pump is maken a weird noise on switching the ignition on. Sounds like valves opening/closing .Any ideas what I can do to troubleshoot?
Personally I hope it's just a glitch
You may want to do yourself a favor and buy a HexCode GS=911 (or similar) ... that way you can pull diagnostics yourself and you will know what it is that ales your ride ... and reset it if needed ...
Yeah, I might consider it in the future. Only if it is for resetting the yearly maintenance warning.
