?Is anyone here in a position to recommend Joggers? Thanks xox
I guess I’m a little slow on the uptake. Are you implying that R 18 Classics should have been delivered to buyers with floorboards and not foot pegs? I think my dealer was a straight-shooter, but who knows?I was able to get a copy of the floorboard part numbers from a friend at a SoCal dealership. They are very scarce because the first batch will be installed on R18 Classics that were delivered to the USA with footpegs instead of floor boards.
R2K, I just received the floorboards for my First Ed. and wanted to know if there where any tips or recommendation about the removal of the bake pedal before I begin installing? Thanks.My parts were delivered today, installation tomorrow
View attachment 601View attachment 602View attachment 603
Not really it’s very straightforwardR2K, I just received the floorboards for my First Ed. and wanted to know if there where any tips or recommendation about the removal of the bake pedal before I begin installing? Thanks.
Hello, I installed a 5mm thick spacer between the pedal and the plate, so that the brake pedal is in the same axis as the brake master cylinder. To make the spacer, I used part number 7 on the sight. Good day.Not really it’s very straightforward
Thank you!Not really it’s very straightforward
Thanks for the good idea for a 5mm spacer. I'll order the part.Hello, I installed a 5mm thick spacer between the pedal and the plate, so that the brake pedal is in the same axis as the brake master cylinder. To make the spacer, I used part number 7 on the sight. Good day.
with my google translator friend.
