Hexcode GS-911 Status on R18's
Svtweb
Moderator
Staff member
Elite Member
Plugged my GS-911 into my R18...
ABS unit is something totally new, not recognized at all. Alarm system, engine, instrument cluster and lighting controller are all existing units, Bike family not known. Working with HexCode on all the dumps to see what they find.
Reactions: Vyk
enzo5000
I got my GS-911 to perform the AutoScan function with my laptop attached. I'm beta testing their new code for the R18. You can contact them directly if you want to help.
  • AutoScan Report for R18.pdf
TodkaVonic
Elite Member
Do either of you have any experience with the GS-911 and iPad/iPhone? There's an app with mixed reviews. Some functionality not accessible, etc.
Svtweb
Moderator
Staff member
Elite Member
I use it on my iPhone all the time and it works like a charm. As long as you have internet capability you should be fine.
TodkaVonic
Elite Member
Great! Thanks. Would you recommend that I wait a bit so that it works as intended with the R18, or are there anticipated software updates, etc? Or does it work as intended now?
Gaylord Poe
Premium Member
Good afternoon. Any word from HexCode? I am needing to reset my service light.
theMucker
Premium Member
Hi Enzo5000. You are apparently well versed in modern BMW ownership.
I see that Amazon lists the GS-911 and it appears that it does not come with the necessary pigtail to connect to the motorcycle. It also refers models to as WIFI & USB. Can you please clue in us guys who are new to owning a modern BMW? What model of GS-911 and cables are needed for diagnostic testing and code resetting? Are there issues that such a new BMW model may not be addressed with the GS-911? Are you aware of better sources to obtain one, beyond Amazon.com?
enzo5000
The GS911 plugs directly into the rectangular OBD-II Diagnostic connector located behind the right side panel. You can get basic info using the App with a smartphone. To drill down into the more sophisticated info you need to connect to a Windows computer via the usb cable after you’ve installed the GS911 software.
theMucker
Premium Member
Thanks for the info Enzo5000!
So the GS-911 wifi with OBD-II Connector is the one to get? Do we need any special connector cable?
https://www.hexcode.co.za/products
Black Dog
Page 102 in the owners manual. If a all else fails......
As they in Brazil, "Que porra isso"
theMucker
Premium Member
Thanks. I have checked out the owner's manual. But it's not especially clear in so far as whether or not the GS-911 requires a cable/pigtail to connect to the R18. It this point, it appears that no interfacing cable is needed.
Black Dog
Depends which GS 911 iteration you have.
As enzo5000 stated,
"The GS911 plugs directly into the (rectangular OBD-II) Diagnostic connector located behind the right side panel."
Self explanatory. There are even instructions on how to access the plug.
The picture on page 102 actually shows the ODb-II rectangular plug.
See Dunning for more information.
theMucker
Premium Member
The day after I ordered a GS-911 on Amazon for $400 they're posted for $300!
It says there are 5 in stock. Those who want one should strike while the iron's hot!!
TodkaVonic
Elite Member
Is all the software and hardware and firmware updated and compatible with the R18? Full-functionality?
Addendum: I see it says compatible with all models after 2017 but I’m not seeing confirmation on the hex code website. Only mention is here:
From a November firmware update. Also I would need the WiFi version. No windows in my house.
Gaylord Poe
Premium Member
The upgrade for support of the R18 is not yet released. I wish they'd hustle up!! Waiting on this, and accessories, and a Repair Manual DVD is crazy!! If I'd only known all of this when I decided to purchase my R18...I expected better out of BMW...
TodkaVonic
Elite Member
Bummer. I’ll be waiting as well
Black Dog
If you are in an all fired hurry, you could always take it to the dealer. I am sure that for them to just clearing a fault code would be much less than the cost of a GS 911, you could probably get the first service done too in the bargain. Or just take it for the first service, which I always have done by the dealer anyway, and the will clear all the fault codes as part of the service.
Black Dog
Have the dealer do the first service, resetting the service light is included.
Todays scan turned up 3 fault codes, reset, no sweat.
Also reset fault codes and service reminder on the K1600B.
Works just fine.
Gaylord Poe
Premium Member
I should've included the fact that I already own a GS-911 and do all of my own service/maintenance including the first service. But thank you!
