installing the Madd exhaust.
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1731440888#check"></use></svg></i> Discussion starter Discussion starter oldslodog
oldslodog
Houghton lk. Michigan
r nine-t k1600b k1200lt
I ordered the Madd exhaust from the company in Denmark. Took 6 weeks to show and they won't fit. Has anyone here installed these? What did you use for flange/collar? I contacted them and evidently, they haven't installed a set either. They say the collar/flange slides on from rear, this is not possible. thumbnail (54).jpg
That was the suggestion from manufacture if I chose to do so. They say the o2 sensor bungs are too long to slide on from rear, machine down or they will send new ones. They don't machine those three notches. Still waiting after I pointed out the other manufactures have the notches too.
