Innovv 3rd eye
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Ferrett2055
Ferrett2055
UK
2023 BMW R1250GSA, 2021 R18 FE, 2001 K1200RS SE.
Has anyone fitted an Innovv 3rd eye system to a Transcontinental? If so, where did you locate the control unit. I’m collecting my new (to me) TC on Monday and am looking at options. I’ll be fitting a Hex EzCan from my FE together with some lights but will have spare channels and thought I might go for the third eye, either with or without a camera system. Does anyone have any advice?
I have a Garmin Zumo XT2 Nav unit using a Mottorrad Audio mount and have a Garmin Zumo Radar system mounted on my R18B with Givi topcase using the TC rack. It works great and pairs with the Zumo XT with a readout showing cars and locations of vehicles around you. It is very small and does not use a separate control unit so it is very easy to install. It also can be installed without the Zumo XT by using your cell phone as an interface. It also has the light indicators that mount on your mirrors.
Dan
https://www.garmin.com/en-US/p/1227031/
https://www.motorradaudio.com/colle...zqOoPoc-DAr5Jntc7BDXsAchH1L06d1AUIw7pUJe7YiMI
looking for a mounted Carplay display what's the best place to tap for accessory power?
HEX exCAN might be over kill....
Thx!
Thx!
Have a look at the Motorrad Audio YouTube channel. They sell a mounting bracket that you can mount a car play unit to and show you how to get power to it.
