Aftermarket Footpegs
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter jollygreen24
jollygreen24
Currently r1250gs looking at a r18
Hello All,
I was just curious if anyone has had any luck fitting aftermarket footpegs on their R18 First Edition/Standard.
I am wondering if footpegs with a standard male mount would work. If so, when installing, did you have to remove the spring from the footpeg assembly to make it work?
Any advice is appreciated! Thanks!
