Air filter secure enough?
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter johndeeredr
johndeeredr
madera ca
R1800B
Removed the engine cowling to remove and replace the engine air filter . Just bought the R18 a week ago and doing a complete service. I discovered it had a k& n filter already in it . Cool, so I removed the tie down clamp , that was a pain ! Cleaned and re oiled the filter . Reinstalled and then installed the clamp . I noticed it barely secured the filter to the air box . Is this normal or did I do something wrong? Can’t see anything I did . I doubt it’s going to be a problem but would like to here some feedback thank you from expensive California.!
