Fitting tyres
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1758297946#check"></use></svg></i> Discussion starter Discussion starter David1962
David1962
Melbourne
BMW R18
Can someone please guide me for replacing Wheels front and rear.
Front 21 x 3.5
Rear 18 x 5.5
What is the maximum size can I fit for the rear wheel
Thanks
See attached for a general guide. Depending on the type of exhaust you may need to remove the cans as well to access the rear axel. Not hard just tedious. EDIT: sorry the wheel removal PDF is too large to attach. Search for the guide online, it’s in the virtual maintenance manual.
