Front tire bumps on Michelin Commander III
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1752603775#check"></use></svg></i> Discussion starter Discussion starter Ninja
Ninja
2022 R18 Transcontinental
Hi guys and gals,
I noticed these bumps on my front tire after a ride yesterday. It's a Michelin Comander III with 5300 miles. For peace of mind, I'm going to get it replaced before a 700 mile trip but was curious what it is and if any one has experienced a similar problem.
Thanks in advance.
Yes mine did a similar thing and the next tire that I tried (Metzler Cruisetk) did that too . after 8500 miles
Thanks, Ulrich.
After additional research, the term to describe my issue is cupping.
I’m not sure that is cupping. That is a bulge through the belts of the tire. Probably fractured belts maybe allowing that to happen. That is at high risk for a catastrophic blow out. Your tires are the old version of the commander 3 which Michelin started to replace in 2021 because of the vibration at speed issue. Maybe try the newer iteration. You can tell at a glance if it is commander 3 version two by the tread pattern. All the grooves go nearly to the mid tire. The one shorter groove is replaced with a longer groove. Otherwise I think they are the same tire.
I had to replace the front tire in my R18, a Commander III with 13.000 km because left side was much more wasted than right.
The same kind of wasting happened with the last 3 front tires of my HD. I don’t really know if it is a common point for some models or I just ride different
I'm about to replace mine at similar k's but mine is RHS.... we drive on the left here.
@Noelpolar I had never consider that the angle could affects, but makes a lot of sense
Fwiw.... for some reason, I think I turn to right (on average) harder.... left turns in built up areas here are harder braking and slower (sharper) turn, right turns are a wider radius (so around the roundabout etc) and normally are higher speed pushing the front more etc.
I also am having trouble with frt. tire. Recently acquired my second R-18. This one has the 19. inch frt. wheel versus the 16. inch on my classic. The bike has only 1500 miles but appears to be starting to cup. I'm noticing a vibration I thought was engine but am wondering if not frt. tire? On the classic I bumped the pressure up a couple pounds and it was better. These bikes are heavy on the frt. tire but I managed 10,000 miles before the wear bars started getting close. What tire pressure are all of you running?
My R18 B felt loose on the road Saturday morning; I checked the tire pressure and I was down approximately 6 to 8 lbs psi on the front and rear tires... Filled with air for Sunday riding, and I could notice the difference; the bike felt much better on the road...
It only takes a minute or two to check and fix tire pressures... Totally worth it..
