Several things I'd check for:Is there anything I should check for why I’m not getting fuel now?
bingo! I’m an idiot. I hadn’t reconnected the wire harness. Took things back off to clean up my wiring and realized it.... did you plug everything back in? ... had that issue on a friends Kawa ... then realized we hooked up the fuel line but never connected the wires back to the fuel level sending unit.
WooHoo! .. I bet that is the first thing you check from here on outbingo! I’m an idiot. I hadn’t reconnected the wire harness. Took things back off to clean up my wiring and realized it.
....Or, double-check if you reconnected the wire harnessbingo! I’m an idiot. I hadn’t reconnected the wire harness. Took things back off to clean up my wiring and realized it.
