Fuse Location for Turn Signals and High Beam Switch
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter mikebeavers
mikebeavers
Texas
R18
I wired up aftermarket turn signals and when I put things back together, the turn signals and high beam switch are not functioning. Is there a fuse for these? I can not find any documentation on it. Maybe a fried Relay SW? Ideas?
Which R18 Model are you trying to catch fire 🔥 to...?
Below is the TC Owners manual:
It showed the warning light but I had no way of seeing the codes. I gave up and took it to tue dealer. Turns out it was just a loose connector
I didn't want to ask if the lights were plugged in; it probably, would have come across as being a smart ass...
Now we know.. glad you got it sorted out; I have parts arriving from Germany and there is a bunch of electrical work that is going to be needed in order to get the rear lights working... I'll double check my fitted connectors.
Just my 2¢ ... do yourself a favor and buy a HexCode GS-911 ... it really comes in handy for many things ECU/CanBus related ... it is not cheap ... but, what on these bikes is!
Agreed... It pays for itself after two 6,000 miles service appointments at the dealership...
