Getting my ride hauled .
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter johndeeredr
johndeeredr
madera ca
R1800B
My R1800B is being put into a Haul bikes truck and is being delivered to me . Harley had a way to put the alarm system into transport mode so the battery won’t drain during transport. Does my new ride have the same ? And how would you put it into transport mode?
I had an R18 Transcontinental trucked to my place. Can't remember the driver doing anything to "undo" a hidden "transport" mode. My current R18 does not flash uncontrollably like the Harley Fatboy.
Have the classic. I assume the B DWA is similar
To deactivate the movement sensor (for example if you are about to transport the motorcycle on a train and the swaying movement of the moving train could trip the alarm signal), press button 1 on the radio-operated key during the activation phase. Turn indicators are illuminated three times. Movement sensor is deactivated.
Not sure regarding battery drain. I think alarm has its own battery. It can be disabled completely if needed.
If you have the anti-theft alarm system installed there is a tilt sensor that can be deactivated in settings if transporting.
