HeliBars with Ram mount - BMW R 18 B Tour Commander 2022+ - SOLD
I am so tempted to pull the trigger on these.... I think there is a blacked out R18B on this site that has the same bars installed, but I can not find the pics right now.
Cables NO, fluid lines YES, but for someone who hadn't done it before, and was totally petrified at the prospect..... it's sooo dumb, follow the instructions as they do a really good job, to the point I didn't need to add any fluids after, minimal/marginal loss (drops). then you purge right at the middle with the bleeder valves on the banjo bolts they provide. Super easy (JUST DO NOT ACTUATE the brake or clutch levers while replacing the hoses and it will take you 10 minutes max per side).
Be patient, and take your time.
And if in doubt, take pictures as you go.... but it's simpler than it looks, looks very intimidating once you start the process.
