If you haven't removed the fishtails for inspection....
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter 1911tex
1911tex
Texas Hill Country
BMW R18 First Edition
Suggest it is a good idea for whatever future reason you may need to remove the fishtails. Especially on the right side on my bike. The rubber grommets on mine had dried somewhat and I had a devil of a time once the circlip was loosened; trying to pull the 2 fishtail male thingamajiggies out of their respective rubber grommet brackets! I finally squirted some PB Blaster, let it soak into the grommets for a couple of hours. Then clean and lube and reassemble. Tighten circlip to 18 ft.lbs. Might save some time and frustration in the future if a need occurred.
