Longer Brake & Clutch Cable Installation
enzo5000
I'm planning on installing longer brake and clutch cable to accommodate the handlebar risers I bought. Has anyone gotten to the clutch bleeder valve behind base of the drive shaft. It looks tight in there.
You are talking about the slave cylinder behind the battery?
Item #1 shown below should be the only hose that needs replacing.
It is located under the gas tank.
