Lowering the brake pedal
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter johndeeredr
johndeeredr
madera ca
R1800B
Found this way to lower the brake pedal on a 18B . Acts like stop but you will need to adjust the master cylinder push rod yoke . So far so good . Now I’m Able to just move my foot forward or even lightly rest it on the foot pad .
Yeah I thought about that . I might go has far has getting something custom built to match the rest of the bike if this works out . So far I’m really liking not having to raise my foot and point it in .
Any chance, does the new lower position activate the Brake Light..? Probably worth checking..
That hopefully will be activated via a pressure switch, in that case it wouldn't matter where the lever is as long as enough brake pressure is sensed 😉
