OEM engine guard size
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Ridout
I don’t have them fitted to my bike but if you download the Motorrad app and register your bike, you will have access to all sorts of interesting stuff (the app is not perfect)
One of the stuff you will get access to is your user manual as well as the OEM catalog for aftermarket bits.
Hope this helps
Hope this helps
hi my 2023 transcontinental engine bars are 30mm tube size
