Oil
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Sandpiper
What is a great oil for my R18TC?
  • Total voters
    4
Sandpiper
FL
2022 BMW R18 TC
If anyone is interested I switched to MOTUL 7100 15w50 at 24,000 miles from Advantec Pro 15w50 and have found it to be superior in that it smoothed out my engine and increased my fuel economy. I contacted MOTUL and asked about going to 7100 20w50 because I live in S. FL or switching to 300V either viscosity and this was their response. They also provided me all the testing specifications of both oils along with more useful information if any interested in the full report I received just ask. Here is the summary of what they suggested:
"In summary, we recommend sticking with the Motul 7100 15W-50 to align with BMW's specifications for optimal performance across your varying climates. If South Florida's heat proves particularly challenging (e.g., consistent oil temps over 250°F), consider testing the 7100 20W-50 during your time there, but monitor for any changes in cold-start behavior upon returning north. The 300V, while superior in racing scenarios, isn't ideal for your street-oriented use."
Appreciate your comment, but for me I will stick with MOTUL, has a proven history and very solid test results in every application.
Everybody has their thing. How many miles do you plan on keeping the bike. Myt R1200R has 83,000 always used Napa (valvoline) 10W40. Now I can buy synthetic 5W40 for the same price, so I am trying it this time.
R18 Gets Mobil 1 15W50. I sent a 5,000 mile (35,000) sample in, waiting for results. Not expecting much.
Its what ever you prefer.
David
I'm a fellow Club Motul member. Cheers.
David
Did you get the results back David? All good I assume?
Yes, all good, no moisture, no acid. Similar to the first test. They comment and said it was good.
David
Reactions: LBV
