Plastic plug in socket holder panel
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter MikeSpain
MikeSpain
Spain
R18 100 Years
Hi… I have bought a double USB socket to replace the din plug on my R18, I took the plastic panel off by removing the one screw at the bottom of the panel. After replacing the plug socket, I see I might just have enough room to add the original socket on the vertical face of the plastic panel that holds the din plug and use a quick fit cable from wunderlich to connect the din and the USB sockets. This will mean my drilling out a hole on the plastic cover that holds the din socket… I don’t want to do that to my original plastic panel that hold the din socket and am trying to find one as a replacement part but struggle to fond the part number or name from the R18 parts manual… can anyone shine any light on what the part number is for this unpainted black plastic panel?
Sometimes the BMW part number are affixed to the actual part with a sticker or QR code; maybe try looking on the inside of the plastic cover?
Max BMW has a pretty good website for searching for parts.
Looks like part 6 in the below picture:
Part No. 06 66 12 9 444 700
Sometimes the BMW part number are affixed to the actual part with a sticker or QR code; maybe try looking on the inside of the plastic cover? Max BMW has a pretty good website for searching for parts. Looks like part 6 in the below picture: Part No. 06 66 12 9 444 700 View attachment 17673
Great, thanks for this… i’m in UK so will try and find this in Europe but now that I have a reference number! 66129445047 as my model has the reverse assist!
