r18 classic din power outlet
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter manhattan
I will throw my hat in....yes in my R18 F/E, used it many, many times charging my Lithium battery after a long siesta with my NOCO charger. Never a problem, plug and go. Charges full in less than 30 minutes. If you do a search you will find more information than you ever thought possible on this great forum.
problem solved!!
i re-seated the 15 amp fuse by the battery and re-seated the plug socket connection.
had to turn the din plug back and forth to get a connection but all good now!
