Nice pegs, what make are they?I also installed these highway pegs View attachment 5740
Kemimoto Motorcycle Highway Pegs... https://www.amazon.com/dp/B07D315618?ref=ppx_pop_mob_ap_shareNice pegs, what make are they?
That's quite tidy!
Pretty straight forward. The Kuryakyn multi comes with different attachments. So, you can place them where you want.Nice. What kind of fiddling was needed to install the luggage rack?
Thanks, looks like a good accessory for me. I appreciate the info.Pretty straight forward. The Kuryakyn multi comes with different attachments. So, you can place them where you want.
That was a good move! I used a 1" 1/8th in roll pin to prevent movement. Works well, would be better if a didn't have long legs, but works well enough. Especially at the cost of the pegs. I am gonna rotate mine as you have done as well.@pbosik - I installed the same highway pegs as you. Good suggestion. I added a modification to make sure they don’t move forward with my heavy feet on them. I drilled a .25 inch hole through the clamp and engine guard and installed a 1/4”-20 button head bolt with 1/4” flat washer and nylon insert lock nut. See pics attached. Now they won’t move.
