Transmission Oil Change Question
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Cornel
Cornel
California
2023 BMW R18
Does anyone have the part numbers for the transmission drain plug and fill plug o-ring/crush washer?
I did a search, but could not find anything.
Thanks!
MaxBMW parts fiche comes really in handy for parts and the 'exploded views' help me understand how things fit :)
The prices are about the same as from my local dealership ... so most of the time I just browse there and then order (or if in stock, pick them up) right here in town.
Thanks!
NOTE: Do not try and remove crush washer, it is pressed on at the factory; If you need to replace the crush washer for the Transmission Fill Plug - the entire Fill Plug is replaced as a single part and not just the washer, it also has a magnetic collector on it.
Part No. 23 00 7 683 375 |SCREW PLUG - M14X1,5 as is approximately $30.48
Hi Scott,
Actually the crush washer can be removed by spinning it off following the threads. BMW doesn't officially list the part number, but I've been told a good replacement is BMW Part Number 7119963200.
I have not tried it because I ordered the entire plug this time around, but at the next transmission oil change I will order just the crush washer to see how it compares.
Hi Scott,
I tried threading off the transmission crush washer; however, I didn't want to risk damaging the threads.
I'll try ordering the p/n you mentioned.
