Using Harley Quick Detach rack on R18
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter allenbeemer
allenbeemer
London, UK
Harley Road King
Hi all,
I have been looking for a way to install a quick detach/quick release top box on my R18 classic. I used to have a Harley Road King with the four point mounting system.
I recently found this on amazon https://amzn.to/4fw26mw They say that it fits the R18 and in the pictures it shows an adapter that seems to allow the four point rack to fit to the R18 - picture below.
Has anyone seen or used this or something similar?
Good spot. I have just read it again and it is saying only bagger and TC. Not sure if those have different mounting points. I already have a 4 point docking rack, so I would love to be able to just buy the adapter arms.
I looked at the link. Don’t know if the picture is real or manipulated, but they show the rack on a Classic.
I have emailed them. I really hope that the adapter kit works on a classic as it really would open up a ton of luggage options based on the 4 point docking system.
They came back to me with a slightly confusing answer...
"Hi Allen! This part does not fit your 2024 BMW-Motorrad R 18 Classic.
Replace for 46547925196"
It looks like there is another part number that is compatible with the classic, but I can't find it on the website using the search.
I just googled that part number and found this. Still looks like for Trans Con and not Classic.
I also found that one. But it isn't quick release anyway.
Feels like it might be worth getting a local engineering shop to make a bracket if nobody else is doing it.
I installed this on my bagger yesterday. I'm not sure if the classic has the same mounting points but here's where it attached.
