wunderlich tour pack rack
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter bmwsquirl
bmwsquirl
ohio
2024 transcontinental
paid a good dollar for rack wunderlich doesn't list weight limits.thats because it only holds four pounds.i thought I would pull a h-d move and put fender washers and matching rubber washers.
I laid it out drilled the back two holes w/bolt lengths longer workers great .my plan was foiled by the front two drill holes being very close to plastic being thicker in that area and I used the
supplied hardware.looked good on a road trip with 20lbs gear bag. rear held, front was flexing under wind strain .so I put the bag on the passenger seat for the rest of the trip.really was useless and a waste of good money.
be safe
squirrel
That’s a shame, especially after putting the extra effort into reinforcing it. It sounds like the rack just isn’t designed to handle much more than light-duty loads, and the front mounting points being so close to the thicker plastic definitely didn’t help. At least you found out before it caused a bigger problem on the road. Thanks for sharing the experience it’s a good warning for anyone considering one. Ride safe!
J man
it would have been nice if it was stated on the web page.i saw it on directions.ive purchased from them for my airheads and k75 always good product.......this one the bear got me
