3rd party oil filter for the R18?
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter BER18 100
If you should choose to use K&N oil filters - do not use the built in nut to tighten a new filter on. The nut is designed to remove the filter only. As I stated before - I will no longer use K&N oil filters due to having issues with different filters leaking oil from the welds holding the removal nut to the fiter body. I could have easily been hurt or killed due to oil on my back tire. If you look up oil leaks from K&N oil filters you will see many many cases of oil leaks.
K&N oil filters have a widely reported issue with leaks at the welded nut, especially on motorcycles, due to failure at the weld point from heat/vibration. Users on Reddit report these leaks can occur suddenly, causing oil to dump out, potentially onto the rear tire. This commonly affects filters with the "17mm nut" (e.g., KN-204).
RedditReddit +4
Key Causes and Issues:
  • Welding Failure: The primary cause is the weld for the top nut weakening the canister, causing it to crack and leak.
  • Recall History: A safety recall by the NHTSA was issued in 2017 for certain KN-204/204C filters manufactured between March and September 2016.
  • Reoccurring Failures: Many users on Facebook note continued issues beyond the recalled batch, prompting some to switch to OEM brands.
  • Installation Errors: While many issues are structural, improper installation—such as not lubricating the gasket or leaving the old gasket on—can also cause leaks.
    FacebookFacebook +5
What to Do:
  • Check the Part Number/Date: Confirm if your filter falls under the affected batch from 2016.
  • Inspect the Nut: Check for cracks around the weld where the 17mm nut meets the canister.
  • Use Caution: Many users on VFRDiscussion.com recommend against using wrench-off filters, favoring OEM for better reliability.
  • Hand-Tighten Only: Avoid over-tightening with the nut during installation to reduce stress on the weld.
    VFRDiscussion.comVFRDiscussion.com +2
Oil Filter Leaking........... - VFRDiscussion.com
May 13, 2020 — K&N Oil Filter Issues: Several users report that K&N oil filters, particularly those with a welded-on nut for removal, are prone t...
VFRDiscussion.com
SAFETY RECALL NOTICE - nhtsa
K&N has discovered that certain KN-204/204C oil filters manufactured between March 1 and September 30, 2016, can leak oil at the a...
NHTSA | National Highway Traffic Safety Administration (.gov)
Possible issues with K&N oil filters
Jul 25, 2017 — faffi. ... Reports on forums all over the world reporting that K&N 204 and other filters are failing. One guy had his fail at the ...
California SuperBike School
Anybody have a problem with k&N oil filters loosening & leaking oil? Zx6r 2021 : r/Kawasaki
Nov 14, 2023 — The user says they've had this problem a few times: * "I really have no idea why this keeps happening" * "Seen more than a few lea...
Reddit
Why is my K&N oil filter leaking on my Honda Type R?
Feb 29, 2024 — OEM Filter Recommendation: Many users strongly recommend using OEM Honda oil filters, citing reliability and lack of issues over m...
View attachment 20611Reddit +4
    View attachment 20612Facebook +5
What to Do:
    View attachment 20613VFRDiscussion.com +2
VFRDiscussion.com
Reddit
The correct K&N filter for the R18 is the KN-164, not KN-204. But It does have the 17MM nut. Don't you think they have taken care of the manufacturing defect by now?
I have had several different models leak oil on cars and bikes. They have said in the past that the problems were solved and then had issues again. I simply won't trust that it won't happen again - it is, in my opinion, too dangerous to risk it on a motorcycle especially when other filters are available and filter wrenches are easy to use. I am vocal about it because I don't want to see anyone get hurt - I'm not against K&N. When you consider that they are welding the nut onto thin sheet metal - there is little margin for any error. I had two leak some time after installation so the leaks are not always readily apparent when the filters are first installed. The first leak I considered an anomaly and then three years later had more leak. Luckily two of the leaks were in car filters so there was no danger other than a mess and burning oil smell. It is interesting that the automotive filters are made in the US I believe and the Motorcycle filters are made in China, Mexico and Thailand. Both the automotive and motorcycle filters had leaking issues even being manufactured in several locations.
I've always used the BMW branded fluids, gaskets and oil filters while the bike was under warranty... Plus I own the BMW filter tool.
I'll probably maintain this same trend going forward, even though the bike is out of warranty now..
