adamchandler
A few things, I acquired this data from an anonymous friend. I can't prove its validity or accuracy, nor can I guarantee or warrantee any validity for any other motorcycles than the BMW R18B that I purchased in USA. Countries/Regions/Models/Years will have differences so please, you use this guide at your own risk. I cannot stress this enough. Always consult a BMW Motorrad Dealer and if you can, buy parts & service from them so they can stay in business. I purchase all of my BMW parts from my dealer and have my bikes looked over once a year despite doing my own maintenance.
Service: Rear Bevel Gears AKA Final Drive:
Use Adapter 465821 onto scissor-style lifter with milled recesses in direction of travel
Make sure vehicle is secured so it cannot topple sideways
Block front brake with rubber band and secure with tensioning straps
For Equipment with Seat Heating OE, remove seat and disconnect heated seat connector
Remove the cable strap, release and disengage the connector
Remove screws from inside rear fender and take off side cases from the top
Make sure your alarm is disarmed
Cover rear wheel and tire to prevent contamination with oil
remove oil filler plug
remove oil drain plug
drain oil
Oil Drain Plug in Bevel Gears M12 20NM, replace O-Ring if necessary after checking for damage
Use Syringe (34 2 551) to inject 210ML of gear oil slowly into housing
Use Hypoid Axle Oil G3 - 83-22-2-413-512
Install Oil filler plug with NEW sealing ring, M12 25NM
reinstall side cases (19NM torque) and seat (8NM torque)
Service: Engine oil change with filter:
lift bike as previously detailed above
Remove right ignition coil cover, remove screws (2) and then cover
place collecting vessel under engine
remove sealing ring
remove oil filter
clean sealing surface
lubricate new oil filter at ring
install oil filter
Tighten to 11NM
Clean sealing surface of rain plug
install new sealing ring (crush washer)
Torque M16 to 28NM
Remove oil filter plug using key from toolkit
Pour engine oil until it reaches max mark on sight glass
Capacity = 4.0L
Note, oil level is temperature dependent. higher the temp, the higher the oil level. check oil level only after a lengthy ride or when engine is at operating temperature
Oil part number 83 12 2 405 891 (15W-50 Advantec Pro JASO MA2)
Install right ignition coil cover, tighten screws to 10NM
drain oil
remove sealing ring
remove oil filter
install oil filter
Tighten to 11NM
Torque M16 to 28NM
Capacity = 4.0L
