Alert ACC Failure on 22 Bagger
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter SoCalMike
SoCalMike
Redondo Beach, California
2022 BMW R18B & 2001 BMW R1200C
I was recently riding with the CC on when I encountered an ACC Failure Warning that cutout and disabled the CC. To keep the bike rolling and make it to my destination I had to disengage the CC. The issue cleared itself by restarting the bike and has not re-appeared. I was in 103°F heat on a really bumpy road so maybe this had some impact. A heart stopping moment when your bike suddenly starts decelerating!
I had my rear tire pressure sensor go bizerk on the same parkway, in the same approximate area; I'm starting to think that something is transmitting on the same frequency band used by the TPS sensors...
It cleared and the tire pressure was all good...
The sensor was clean. And I was in the Mohave Desert so I don't think any stray signals were present. I still suspect a combination of heat and bouncing triggered this glitch.
