accessory port/
On the Model B; there is a plug on the left side of the front fairing instrument cluster and the lower left side near the battery compartment (charging port for the batter trickle charger).
I prefer a direct fused connection to the battery. Use your battery tender plug if you have one. If not attach one.
For the BMW port: you will need an adapter plug. Google is your friend. Your gear can not draw more amperage that be plug can provide; so best to check that.
