Ulrich
Howdy ... well I hit the 6000 miles on the weekend and thought it is time for that valve job / oil change and I thought I share that with you.
Just to head this off at the gate, this is the way I do it to MY bike, what you do to yours and/or if you prefer to have a dealer/mechanic do it is absolutely your business.
But, I thought for those of us that like to do it ourselves ... you might find a couple ideas here
First a little theory:
To do this, the engine should be rotated to the TDC of the compression stroke ... at that time both valves are 100% closed (or they better be)
At that time you can adjust intake and exhaust valve nicely.
I have to also mention that I was a little puzzled that BMW didn't add some sort of service cover to the chest plate (front engine cover) so I would be able to use a socket
on the crankshaft to roll the engine over. That was easier on my 'Chrome-Head' but I am not going to take half the bike apart just to get to that nut.
So I do it the 'old fashioned way, put her in high gear and turn the rear wheel. Well 6th gear is a little over 1:1 on final drive .. that means one rotation (approximately) of the wheel
is one rotation on the crankshaft ... that works for me
Ohhhh .. and before I forget .. I still don't have a lift to get the rear wheel up in the air ... so I went really Barnyard and rolled the bike on the floor
Let's get started. I removed the Valve Cover-Covers (best as what I can call these things)
I kept all the bolts and such together on the side I took them off.
Sparkplugs and all.
This is the view with everything off.
And I want to point out that this is the tiniest sparkplug I have ever dealt with !!! Looks like something from a model engine ... not something that is in an 1800 cc engine!
I don't even have a sparkplug wrench that small ! Had to use a 14 mm socket (9/16" will work too) to get it out.
Well ... anyway .. both sides are stripped to a point where I can get to everything .. and I also removed the crank sensor.
I don't know how many pics can be in one post .. so I figure I best split it up .. more to come ...
EDIT: Please see also post #13, Cornel added the BMW maintenance bulletin .pdf for adjusting the valves!!
Sparkplugs and all.
