Charging the battery
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1758297946#check"></use></svg></i> Discussion starter Discussion starter BER18 100
BER18 100
Kansas
R18 Anniversary Edition
As soon as I got the R18 I bought an "Optimate4" and use it intermittently.
Then yesterday I found this pigtail that had been wired to the inside frame. I have a Deltran battery tender that can use these pigtails. Is the Optimate 4 a better quality product than the Deltran?
I don‘t know; honestly I have owned a few CANBUS Beemers and have had terrible luck with the fancy chargers. I attach a pigtail directly to the battery and use a simple battery tender. I am critical when necessary but I will give the R18 battery props. It has lasted me 4 years and my batteries never last 4 years :-). I don‘t run accessories on my R18; I just use the dongle directly off the battery to use my heated gear… I don‘t believe the electrics will support heated gear as accessory. IMHO direct to the battery gives you a better chance of your tender working best for the battery and not making a mess with your electrics but your mileage may vary
To each its own. I've use the very same Optimate 4 on my last 4 BMW bikes and never had an issue. All batteries lasted > 3 years.
But yes, mileage varies.
