Do l have a preference ?
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter kate_brett
kate_brett
Melbourne.
R18 FE
Depends on the ride - where and how far. The TC is a far more comfortable ride ( seat, wind protection and suspension ). TC also handles better in corners - less rake and shorter wheelbase than the Pure.
The Pure is easier to negotiate for parking and U-turn ( approximately 100kg less ). Fortunate to have a choice.
View attachment 21911View attachment 21912View attachment 21913View attachment 21914
You lucky, lucky bastard (Monty Phython quote)!!!
Not only 2 great looking machines, but 1 or 2 accessories fitted as well. So how long have you been single for now?
Singledom happens when l purchase a Roctane.
I found this for you!
The perfect colour and the only model & colour combination that I would have chosen over mine. Unfortunately my dealership didn’t have one available.
I’ll let him know that you are on the way.
Changes / accessories to 2021 ( black ) PURE :
Heritage style front alloy mudguard
Small front indicators
Leather toolbag
Roctane headlight
Beachbars
Custom risers
Alloy bar end weights
Auxiliary lights
Metal oil cooler surround
Roland Sands front engine cover
Roland Sands cylinder head covers
Leather grips
Tank pads
Monza style petrol cap
Wunderlich gear lever extensions ( heel and toe )
Multiple rubber plugs on frame / engine
Alloy mirrors
Computer cable surround on brake/ clutch lines
Heritage tank badges BMW
Denali surround bomb horn
Reverse lever extension
Tractor style seat with custom fabrication for airbags / indicators
Catless exhaust - original headers with welded pipe / brackets / Healtech modules
Removal of Evap system with added module
Alloy rear guard
Saddlebag
Custom numberplate bracket
IMG_6407.jpegIMG_6399.jpegIMG_5666.jpegIMG_5951.jpegIMG_5568.jpegIMG_6403.jpegChanges / accessories to 2021 ( black ) PURE :
Small indicators
Leather toolbag
Roctane headlight
Beachbars
Custom risers
Auxiliary lights
Leather grips
Tank pads
Alloy mirrors
Alloy rear guard
Saddlebag
I’m only at cylinder head covers, front engine cover, various bolts/screws powder coated black, exhaust valve flap deactivated, seat upholstered and recovered, BMW tyre valve caps, various black BMW badges to replace originals, Motoraad 16L bags, black Motone keyless fuel cap, OEM lockable fuel cap powder coated black, Bar end mirrors, Gremlin bell, custom engine plates, sports air filter, black handlebar clock otw, black aluminium radiator cover, custom upper fork covers, frame plugs, ‘Limited Edition’ plates otw, smaller number plates and plate cover, round Australian flag aluminium decal to replace rubber grommet on rear guard and front fork spindles.
Certainly not quite in your league, but that’s not too bad for 8 months of ownership.
If I had money to burn, I would have a custom tune after decatting the exhaust. Also, probably a bit more exotic looking seat cover (without going overboard) and getting it painted Dragon Fire Red.
It’s a sickness , you won’t stop with above.
