Not really I had to call them to order my parts, you will need to know the O/S diameter of you engine case guards.I found the R18 on their website but although all of the pictures show them mounted on an R18 they all say for R18B and R18T. Am I missing something?
OK thanks. I will give them a call.Not really I had to call them to order my parts, you will need to know the O/S diameter of you engine case guards.
The canopener is a unit you plug in between your alarm module and the canbus system that allows you to program your lights you still need to source the power directly from the battery the other option is a stand alone relay control module that you need to install and frankly there isn’t much room on the R18 standard or classic to do it. The canopener also has wiring to provide power and programming for the Billy brake light.Not sure what the canopener billy lights are? They are the Erica model. I did not get the yellow lens cover but Im sure I can get those separately.
Just checked my invoice and yes the CANopener is coming. She said they it is plug and play and comes with an adapter for my bike since I dont have the Wonderwheel like the B and TC. I do like Billy brake light and may add one later on.The canopener is a unit you plug in between your alarm module and the canbus system that allows you to program your lights you still need to source the power directly from the battery the other option is a stand alone relay control module that you need to install and frankly there isn’t much room on the R18 standard or classic to do it. The canopener also has wiring to provide power and programming for the Billy brake light.
https://www.clearwaterlights.com/collections/motorcycle-led-brake-lights
https://cdn.shopify.com/s/files/1/0...-e138-44b1-807d-7980a2416d3e.pdf?v=1670023411
Yellow lens cover, When I bought my lights they threw those in. I Didn't think I would need them. They actually come with a rubber holder that fits over the lens. I figured out quickly that with yellow lens covers during the day, really makes you stand out on the road! (Lots of cages get outta your way quickly! They quickly slip on and off. Also helps with bugs. maybe stones thrown up too Never had that happen though. Lights are 10% power at night low beam (still get flashed sometimes) and on hi beam its "GOOD MORNING AMERICA"! LOL During the day I want to say, I Think I read in the Literature, the lights are 30%?Not sure what the canopener billy lights are? They are the Erica model. I did not get the yellow lens cover but Im sure I can get those separately.
