Engine Oil
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter MilwDave
The R18 is both air cooled and oil cooled. The oil cooler is thermostatically controlled. The oil is kept at a very stable temperature so changing oil weight is not necessary for different OAT due to seasonal changes.
Can't resist stirring the pot - my Transcontinental Rider's Manual, on page 169, says: SAE 15W-50, API SJ / JASO MA2, BMW Motorrad recommends BMW Motorrad ADVANTEC Pro. Maximum of 0.5 L for a top up (between the lines in level glass) and 4.0 L for an oil change with a new filter. I use Penrite 4-Stroke motorcycle oil, 15W-50 - a fully mineral version (API SL, JASO MA2). Penrite MC-4ST 15W-50. Liquid gold, imho. I think BMW's ADVANTEC Pro is a semi-synthetic? So might need to get with the times and swap to a semi-synthetic?
In Aussie land, I go this Penrite after I have 10,000kms on the motor:... so after warranty for the most part.
Normally buy it 40% off around the boxing day sales. It's marketed a bit along the lines of "factory racing" but unlike the Motul V it has the appropriate additives for road use. The bike sounds different then when the BMW oil was in it.
Good point on having a thermostat with the cooler...
The R1200C (and various 1100/1150 variants) were also oil cooled, but I'm not sure if they were thermostatically controlled... I'm gonna have to do some research on that one.
