Saunders
Well I finally swapped out my floorboards for the R18B flat pegs and realized what an improvement it turned out to be. With the boards, you have to place your feet further apart while at a stop light. The pegs allows you to place them inward towards the bike and get both feet flatter on the ground, which makes it much easier to stand up while at a stop. It's also easier to back the bike up with your feet since the floorboards would be right up against your shins and the pegs give a bit more room to maneuver.
Also with the floorboards, the heels of your boots are resting above the board which in turn causes your knees to be up higher. If you have an inch or so heel on your riding boots, then your knees are that much higher as well when resting on the boards. The flat pegs allows the heel to rest below the peg not causing as much binding in your knees. Plus I think its easier to pivot your ankle on the pegs to shift gears and not have to reposition your foot into place. For just straight highway cruising, the boards are comfortable I'll admit. Of course this all comes down to personal preference.
Not sure if anyone else was having this issue, but with the floorboards it was tricky trying to engage the kickstand as only a small portion of the stand was exposed. With the boards out of the way, there is much more room to get your heel onto the kickstand and swing it open. That's a big plus.
The only negative I've found with the pegs, is the rear brake lever seems to be in the way slightly. You can turn your foot outward a bit and not a problem, but with them straight ahead it feels as if you would be riding your brakes with your foot inadvertently on the pedal. You just have to be subconsciously aware. Again not a big deal, but I may try the peg style brake lever and see if there is anymore room. It seems the bikes with floorboards all had the flat style lever while the round peg bikes all had the peg style brake lever. Don't know if they're that way for a reason, or just aesthetics.
