Star-Lord
I agree
regarding the front wheel drag on the disc brakes ... My R18 B sounds like I'm spinning a rusty saw..
It really sounds like your bearings are just fine! ... and yes with the original tire the noise was terrible and it did sound like a dead bearing!! ... Changed tires and the grinding noise all but went away!!Last night, I put the bike back on the hoist and removed the calipers to rule out any dragging or related noise. I used a stethoscope while spinning the wheel as fast as I could, both forward and backward, and I used the stethoscope on both the left and right forks and both spacers. There was virtually no bearing noise or growl. While there was no load on the front suspension and the wheel was spinning slowly, I would expect some noise if the bearings were as bad as the sound suggests when riding.
This makes me suspect that my five-year-old tire might be the culprit. It has some visual cupping, though not a lot. The other day, I was riding on a road with a straight, tar-filled groove, and when I entered it, the noise amplified significantly. I'm assuming this is because the entire surface area of the tire, not just the center, was making contact with the road. As soon as I exited the groove, the noise dropped considerably, which strongly suggests the tire is the source of the noise.
I noticed a significant drop in road noise when I switch out the stock tires, to the Metzler tires.
Thanks for the heads up about the loctiteMaybe review the following YT video prior to tearing the fork tubes apart (which I recall from other forum members, is extremely difficult due to BMW's over use of LocTite); the video covers the alignment and tightening process of the front wheel of a motorcycle.
You can go on the BMW website and download the wheel set installation document, in order to get the correct torque values if you don't already have that information; from the Main Menu/SERVICE/MANUALS/INSTALLATION INSTRUCTIONS
https://www.bmwmotorcycles.com/en/service/manuals/install-manual.html#/section-further-manuals
It iz zee correkt prozedur. Und ve haf alvayz done it zis vayThanks for the heads up about the loctite
It was an absolute bear trying to get the handlebar risers off the last time, I'm not sure why they use so much red loctite on everything
Thanks for the insight; I did take the front wheel to a local shop to put on a new tire and they did show me how the front wheel has a slight wobble to it but they said nothing serious. They recommended I checked the fork alignment and possibly check if one of the forks has low/no oil.Do you have the ability to raised the front wheel off the ground, where you can spin it freely in order to observe the issue; if so, you'll must likely hear the disc brakes making a rubbing sound - at least that's what my bike still does after 13,000 miles and heavy use of the front the brake.
Maybe remove the two brake calipers from the troubleshooting effort; remove the brake calipers and tie them off and out of the way, so that you can spin the wheel and listen for any change in the observed noise.
I experienced the different humming noise while on different tarmac coverings across various roads, which seemed to improve drastically after switching to the METZLERS tires; I have the Model B, I also placed felt up and within the shock cowlings, which would ring like a bell if I knocked on them - that also seemed to be a source of amplifying the road surface noise from the stock tires..
I've never experienced any sort of wobble or misaligned wheel issues; see if you can have your front wheel put on a high speed balancer, maybe you need a weight installed. Also, I'm curious as to where the tire manufacture's balance markings (YELLOW or RED DOTS) are in respect to the rim's valve position; again, having the wheel balanced by an EXPERT might help with all of this...
Red? Sofar only found ´blue´ strength.I'm not sure why they use so much red loctite on everything
