Dpolo1
I really like my bike. I don't have an owners manual. My problem is the reverse only moves the bike like 3 feet and stops. Any help appreciated.
That is odd. Would that say something about the current state of the battery?I really like my bike. I don't have an owners manual. My problem is the reverse only moves the bike like 3 feet and stops. Any help appreciated.
I have to check but the engine turns right overAre you getting any error on the gauge? Flashing R?
You are doing reverse while the bike is running, right?I have to check but the engine turns right over
Yes , and battery is fully chargedYou are doing reverse while the bike is running, right?
Try searching the forum, using "reverse" as the search word, opposed to starting a whole new thread on the same topic.You might be touching the front brake lever or something.... quite a normal reflex to slow things down a bit.... any brake, clutch or throttle will stop the reverse function.
Yes .constant until flip the lever to normal.I have to check but the engine turns right over
Welcome to the forum, it’s a great site as you are learning. Would like to see a picture of your R18
It still does it . Roll back and forth not touching anything in neutral . R is flashing when I turn the lever. And when it does work it only goes about three feet .Yes .constant until flip the lever to normal.
