Anyone installed a dash cam system as yet? Finding somewhere for the control unit is proving a challenge. Very limited room under the seat and that area is still exposed to dust and water ingress and is very close to the shock absorber.
On the UK market there is a similar item under the name Thunderbox. Max of only 32 amps though. Denali not as yet doing a CanBus module for the R18.Made my own relay controlled aux power supply panel 16 years ago for the R1200RT, PDM ^) did not exist then.
PDM60 is so much easier to install, and easily programmable.
Studebaker does not make one either.On the UK market there is a similar item under the name Thunderbox. Max of only 32 amps though. Denali not as yet doing a CanBus module for the R18.
I suspect everything will go fine, but just in case ... I have noted trouble with the INNOVV system starting correctly on CANbus bikes depending on the trigger source. If starting the bike is delayed after energizing the ignition, the INNOVV always launches perfectly. I use my NAV recognition as the timer --about a 15 second delay.Back from five weeks away at my place of work. Innovv camera system now fitted and first road test coming up. Will update as soon as possible.
Hi, are you happy with the Innovv K3? I am looking at the K5 or something helmet mounted.Here are some pics of the best solution I have found. I did experiment with fitting under seat but space there is so tight. Unfortunately there is nowhere that I have found which is totally protected from water, dust and mud ingress.
My only disappointment in the Innovv system itself, is the speed of Wi-Fi download. Very slow. I still need to fine tune the system to stop it interpreting every bump as me having an accident.
