looking for compatible bluetooth music player for TC, instead of a phone
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter VARG
VARG
Premium Member
Elite Member
Connecticut, USA
R18FE, R12, R1300GSA
I'd like to provide a music source for my Transcontinental Marshall system without using a phone. Has anyone found anything compatible with the bluetooth device pairing? I've tried a SanDisk player but it was not recognized. I haven't need to maintain communications, nor do i expect to be using GPS any more than I ever have, which is never. Thanks for any ideas, I'll update if I do find alternates.
I’d expect the iPod Touch should work fine. The key issue is which Bluetooth profile the device supports. Android & iOS devices would support the full music control profile which would show the track name, allow control from the wonderwheel & also transfer audio to the system. Some cheaper MP3 players only support the BT Headset profile which is a simpler one and really meant to be used with bluetooth headphones, not a full remote environment like the TC system.
If you do use your phone, you don’t have to use the GPS, nor use it for communications, so there isn’t really a hindrance on connecting to your phone and not taking advantage of all the functionality, but just as a music source.
excellent information on the profile characteristics thanks! i expect i'll find some good options out there now.
eventual goal remains to find a dedicated large capacity mp3 and/or wma player that supports the connection profile requirements.
Own an R18FE and hooked up a Kuryakyn 2720 system on the handlebars. looks fantastic. Sounds excellent. I removed my windshield long ago. Very Happy.
