cheeseBagger
incorrect clutch fluid is not going to prevent the bike from starting
^ that ... harrisrc740 suggested a very easy testing procedure for that in an earlier post ...Wouldn’t be the case that the fluid in the hydrologic system is not enough or there is an air pocket and therefore there is not sufficient pressure to activate the clutch? Maybe even the wrong viscosity can have an impact. As we know, in order to fire the engine the clutch lever needs to be pressed. Just guessing.
Wait... What did I miss? What was the final disposition as to the root cause?Thanks Ulrich , yes it was DOT-4 fluid i used AAAAAAAAAAGH !!!!!!! BMW will repair but as the fluid is contaminated they recommend flush all out and replace clutch reservoir seal , waiting for a qoute sick as !!!!!!
It happens bud. It's not the end of the world and isn't a serious problem. Your enemy now is dealer labour ratesThanks Ulrich , yes it was DOT-4 fluid i used AAAAAAAAAAGH !!!!!!! BMW will repair but as the fluid is contaminated they recommend flush all out and replace clutch reservoir seal , waiting for a qoute sick as !!!!!!
Ouch!!! .. well the gasket is @ $34 not a big deal ... however DOT4 and that mineral oil really don't like each other. My course of action would be ... ideally ... draining the entire fluid and replacing it with new clutch oil ... this said, I haven't looked yet but it may be that the clutch cylinder bleeder is very hard to get to (please somebody correct me if I am wrong here) ... so instead you could disconnect the line at the upper 'Tripple Tree' and then let the mixed oil completely run out (with the reservoir open) and maybe even run some clean oil after to make sure all (that was contaminated) came out. Then reconnect the line ... IMO the contamination didn't go further than that ... I hopeThanks Ulrich , yes it was DOT-4 fluid i used AAAAAAAAAAGH !!!!!!! BMW will repair but as the fluid is contaminated they recommend flush all out and replace clutch reservoir seal , waiting for a qoute sick as !!!!!!
