As a bit of an outlier, one possible cause is that the clutch master cylinder has an adjustable "piston" that closes when the clutch is pressed so that tne clutch line is presurised..... and when the lever is released it opens so that the clutch reservoir and line are connected and fluid can "equalise". If the piston doesn't travel far enough to open the "port" on release, the clutch line is effectively sealed and the trapped fluid expands with heat and applies some pressure so the clutch can slip..... keep in mind the r18 has a slipper clutch as well so it can be a bit weird.
This has been discussed somewhere here before. I''ve adjusted mine (brake is the same) to fine tune "take up point" but that is another matter.
Generally, a check to see if the piston is set ok is to remove the reservoir lid, press the clutch a few times and see of there is a ripple in the clutch fluid indicating fluid is traveling betwee the line and res.
As far as how this could be so? 1. Not set correctly when manufactured (you bike is newish) 2. The relevant "lock scew" has relased a bit allowing the piston to migrate (lock screw does normally have threadlocker on it). 3. New levers added and piston position not set correctly.
Old man recall suggests someone had this issue 2-3 years ago.
Here ya go.....
https://www.r18forums.com/threads/clutch-issue-for-r18-transcontinental.523/#post-56160
Manhatten matt posted this in there......
"Noelpolar's advice is true and very accurate. The clutch on my 2023 R18 Pure with under 5,000 miles began slipping on a recent 4-week trip to the eastern Canadian provinces. It was diagnosed in New Brunswick to be a slave cylinder issue, but they would not make repairs because USA and Canada warranties are not reciprocated. I "limped" the bike back into Maine, then rented a U-Haul to take the bike to Pennsylvania where I had trailered my bike to meet up with my riding buddy. Once back home in Texas, I took the bike to BMW San Antonio, and the tech there correctly diagnosed the slipping clutch problem to be caused by a misadjusted clutch lever friction point. Such a simple solution for a major problem. Bike is still in the shop awaiting new clutch lever parts under warranty, but I'm assured the problem is fixed. To the OP, please read this post and share with your dealer/service manager."
I only reposted this because no one has ever said I give "true and accurate" anything..... and it wasn't that long ago, though since we adjusted our clocks for daylight savings a few weeks ago time has definately slowed down.... so that explains the 2-3 years.
