Oil Filter -- BMW Part Number: 11427673541 REPLACEMENT
joe
Anyone use the KN-164 filter. I 'think' it's the correct replacement? it has a 17mm welded hex nut can be used for quick and easy filter removal.
Also, Mahle OC306 Interchanges with BMW part numbers: 11427673541
And Mahle Oil Filter - 11427673541 is cross referenced also
And again Bmw 11427673541 Oil Filter is cross reference on K&N site as Kn-164
https://www.knfilters.com/kn-164-oil-filter
Mahle is the current OEM supplier and I've used them sourced from dealers as well as from on line. HiFlo used to be BMW's vendor and I've used them for years too. I have not used knfilters for any of my vehicles, but if it meets spec as to the internals I guess having the ease of access with the 17mm nut addition should make it another good option. Not to argue pro/con for any of them, but I'm picky as there are often huge differences in the internal construction between filters even though they are a name brand and fit properly.
