D
Deleted member 1344
Guest
Deleted
Says the guy who couldn’t read his own oil level a few weeks ago. Lol. All in good fun, and call me impressed at your steep learning curve!…even though I KNOW BMW uses the lowest bidder to bottle their oils....
JASO MA2 is also for bikes with catalytic converters. It doesn't have to be the BMW brand, but should match the spec. If you don't and have an engine issue, BMW can legitimately disallow any warranty coverage for the engine. BMW JASO MA2 oil vs regular synthetic car oil like Mobil 1 is $2/quart difference when bought by the quart. You replace 4 quarts every 6000 miles, so it's $8/6000 miles more expensive. Doesn't seem worth the tradeoff on potential engine issues for such a minor cost difference.It would be fine.But BMW recommends API SN JASO MA2(Japan Spec Oil 4T to be used in wet clutch motorcycles) .
That being said,If you aren't going to use BMW oil, I would recommend at least staying with the BMW requirement.
I don't want to start a oil thread but I highly recommend this oil:
https://www.ebay.com/itm/334100163602?hash=item4dc9ebec12:g:6lsAAOSwnE5hqS44&amdata=enc:AQAHAAABANRgsJsYrmaBJseGRjVV5v7kbGv/rRjRFOXOtCuEyI4KTNEAvhufOrKJBLR5G1Mdst3n1AlkU9jAU+5UB1cnU21aLv+rVKge0ePJ7Wn3EuYOnhylRwpbQRXxOrPl03T1EpRLy7f40oiGgF/NZt/o0kTKjaH6humnIUnMUy8r/kDQF4YHLezw+OEB3WOgiHf8aOX9tkGkp71yIMb3LvvAs9RpPa3x09lJwaZ5uFjPao6nU8KnhWjXYbGuSd+QeriMenyOVTJb23VTdZ8yDUNoLbsUwUpHq/+VtbWalpVAbQjoD3UjTaPlD7TyWHl+MmI+jl810wzAvBtbK+6OxXMi7UE=|tkp:BFBM_vT96sVg
It is the correct spec oil and comes in 1L bottles buy 12 for about $100 and get 3 oil changes.
I have been using their 20w50 full synthetic oil in my Indian 2017 Limited since it was new.
Lastly,it is cheaper to buy the 12 bottles on eBay than directly thru them.I believe their refinery is located in Florida and they make oil for companies that put their own labels.
In the end use what you like,I do.
Indeed, the silly expense of using a oil that could cause difficulties down the line is not worth it, I will have all my service work done by the Authorized dealer PERIOD. I will ask them next time around why there is no oil in my sight glass !! That has me going nuts.. jpJASO MA2 is also for bikes with catalytic converters. It doesn't have to be the BMW brand, but should match the spec. If you don't and have an engine issue, BMW can legitimately disallow any warranty coverage for the engine. BMW JASO MA2 oil vs regular synthetic car oil like Mobil 1 is $2/quart difference when bought by the quart. You replace 4 quarts every 6000 miles, so it's $8/6000 miles more expensive. Doesn't seem worth the tradeoff on potential engine issues for such a minor cost difference.
If you buy in bulk like R18C says here for one that matches spec even if not BMW brand, it's even cheaper, but also still won't invalidate warranty.
more than a few of us are curious too.Indeed, the silly expense of using a oil that could cause difficulties down the line is not worth it, I will have all my service work done by the Authorized dealer PERIOD. I will ask them next time around why there is no oil in my sight glass !! That has me going nuts.. jp
Being prescribed for engines with catalytic converters doesn’t mean it is going to lubricate the catalytic converter itself and thus blowing past the rings. It’s that the tolerances and performance requirements for engines with catalytic converters aren’t the same as those without them.Think about this for a moment. The BMW Advantec oil is prescribed for bikes with catalytic converters. If oil is reaching the catalytic converter, then it must necessarily be blowing past the rings.
A new motor burning oil would have me more concerned about the quality of the engine than the brand of oil. Since when is my new R18TC burning oil at 1,500 miles?
I apologize for any tone containing sarcasm. Your answers are always complete and often supported with graphics.
I misunderstood the thread by nielsm that production tolerance is different when a cat converter is in the mix.
I think you misunderstood me as well. Modern engines that have to meet emissions and noise requirements while having good performance have different tolerances, thermal considerations, etc than older engines and thus require higher specification oils. It isn’t the act of adding a catalytic converter alone that would change tolerances (certainly not lower). In fact BMW bikes have had catalytic converters since 2000, yet JA2 wasn’t available till 2006.I apologize for any tone containing sarcasm. Your answers are always complete and often supported with graphics.
