Oil Site Glass Replacement?
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Radd18
Was the old oil "milky" when you changed it? That would indicate condensation / water in the oil. Try adding some Seafoam to the oil to absorb the moisture.
Yes, It was milky. I thought at first water leak but then realized it's air and oil cooled engine so did not think much about it.
