Poignee chauffante
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1758297946#check"></use></svg></i> Discussion starter Discussion starter jp R18T
jp R18T
Bmw R18 transcontinental
Question idiote : le remplacement des poignées chauffantes sur la R18 , sans acheter les très chères poignées d'origine, on fait commentaire ?
quelqu'un a une solution ?
You can buy Domino or Ariete replacement grips for around 30 Euro. Then you need to cut the current grips gently ( there is a heating element underneath ) and put a new grips. I did it on my GS and also on my FE. Just look for ''BMW replacement grips'' and then go to Youtube, you'll find several ''How to replace BMW grips'' videos.
