Berardi3
- Joined
- Jun 2, 2022
- Messages
- 317
- Location
- Ringwood New Jersey
- Bike
- 2022 BMW R 18 B 1991 BMW K75S
My tire is not cupped thoughMine wobble and rumble sound was because of cupped front tire.
Still original tiresHow many miles on your bike?
New tires recently mounted or stock tires still on the bike?
Maybe an unbalanced front tire; any evidence of missing wheel weights?
You can try to see, if the wheel indicators are still visible, and compare the color (DOT) location in reference to the air valve?
Do you have the ability to raise your front tire off of the ground, in order to spin it freely? Any chance do you have the KERN-STABI X-518 stand?S
Shouldn’t the manufacturer’s balance mark be OPPOSITE the valve?
The YELLOW color DOT marks the lightest part of the tire, and is typically aligned with the heaviest part of the wheel; which, is where the valve stem or TPS sensor is located..Shouldn’t the manufacturer’s balance mark be OPPOSITE the valve?
I agree with this statement 100%... It's how I understand the science behind mounting tires...A Red Dot is not the heaviest part of the tire it is the highest point (out of round) and would be aligned with the lowest point on the wheel if marked. If both red and yellow dots on the tire and no marking on the wheel the red dot is aligned with the valve stem. Picked this up from an old tire fitter.
