Question Question about servo eliminator
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1758297946#check"></use></svg></i> Discussion starter Discussion starter jung
jung
south korea
r18 first edition
이것이 Hilltech Servo Eliminator를 설치하는 올바른 방법입니까?
1. 서보 엘리미네이터 장치 2개를 구매하세요.
2. 차가운 자전거에서 기존 커넥터를 분리합니다.
3. 구입한 서보 엘리미네이터 유닛 2개를 커넥터에 연결합니다.
4. 자전거를 시동하세요.
이것으로 플랩을 100% 열어서 설치가 완료될까요?
또는 1~3단계를 완료한 후,
서보 모터 케이블도 분리해야 합니까?
You also need to disconnect the servo cables from the servo exhaust cam wheels, two cables on each side of the exhaust:
At that now and the cables are pretty tight. Sofar cannot get enough slack to get the anchors unhooked from the wheel :rolleyes:
Can understand that some simply cut the but want to avoid that.
You are saying that just loosen the adjusters all the way and the cables will no longer actuate the flaps? They will remain open? The flaps are normally open when the bike is off and the cables will be too loose to close them. Voilà!!! Does this achieve any real advantage other than disconnecting emissions control? More power, run better, etc?358278208_179281745124114_8952618695633534097_n.jpg
You are saying that just loosen the adjusters all the way and the cables will no longer actuate the flaps? They will remain open? The flaps are normally open when the bike is off and the cables will be too loose to close them. Voilà!!! Does this achieve any real advantage other than disconnecting emissions control? More power, run better, etc?View attachment 18800
No I stated to remove the cables from bracket. You been drinking?
But the part about why, why do it unless it gives more power or runs better?
As the valves only close at small throttle openings, it has no effect on power.
1. It will have an effect on sound under those conditions as that is one eason why it is there.
2. The other reason is emission control. Keeping the downpipe full of gasses means those gasses burn all unburned CH off.
Right so what will keeping is open give you?
1a. Slightly more audible burble.
2a. This one is two fold. The slowed down exhaust gasses will pass more heat to the header et al so keeping it open will run cooler under those circumstances. The last one is obvious as the now not all burned CH will pop a bit more.
Thus keeping it open gives you:
- nice burble
- running cooler still
- a few extra pops
For me the cooler running is the crux.
I thought Petrus is saying that. My mistake. But the part about why, why do it unless it gives more power or runs better? Not drinking yet but maybe later. Cheers!
To remove the servos altogether ... now I can use a regular jack ATV and/or Scissor to jack up the bike like any other bike I had before ... there is no real performance difference that I can see ... the popping at 'Dynamic Engine Breaking' is a bit louder and the bike 'grumbles' a bit more in idle .. but really nothing power wise .. just very convenient when you do have to jack the bike up ... and I will have a cold one in a few as well ... cheers!
One bolt drops the entire servo unit. Now you have slack.
When I pulled the wires off I noticed one of the coil springs was split into two pieces providing no butterfly torque. So I grabbed some bale wire and wired it in the open position.
