R18B & TC TPMS sensors $$$
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Deleted member 939
D
Deleted member 939
Guest
The TPMS sensors in the R18TC & B are the same ones used in the Indian Motorcycles.
There is 1 difference.The BMW cost over 2xs as much.
Hope this will help someone a couple years down the road.
I bought it without the tpms (rdc) option. (R18B)
I'm curious about how to install the tpms option.
Please tell me if you know
thank you
The Indian Challenger base model comes with out the TPMS.
I'm told that all that is needed is to add the sensors and the system is already there.Just needs programed.
I'm sure the BMW dealers will charge a bit more for this.
One guy on the Indian forum is having his installed when he needs new tires.Another guy on the forum did get a base Challenger with TPMS that was installed by the dealer.
Since the tires need to come off for the install you will need a programmer to get them to work.
Good luck
